It is currently Tue Nov 04, 2025 6:47 pm
 Post subject: Anyone added vent lines to 2013+ bags?
PostPosted: Sat Apr 26, 2014 10:28 am
Like the title says, anyone added vent lines to a 2013+ bags?
Getting tired of burping my bags to make sure they are full. Looking at the boat, I think I am going to just get a y connector and tie into the vent line from the hard tank. Anyone have any photos or tips to get to the vent line for the hard tank?
2013 A20
 Post subject: Re: Anyone added vent lines to 2013+ bags?
PostPosted: Sun Apr 27, 2014 11:56 am
Bump this up, considering it too.
PostPosted: Sun Apr 27, 2014 12:41 pm
I think "dat Texas boy" did. But not for sure. I know I have seen it on here.
PostPosted: Sat May 24, 2014 9:44 am
I vented mine. Rerouted majority of the plumbing to do it. Fill and drain times seem adequate to me. Lines go as follows:
Pump to anti-syphon to the back barb on the front of the tank (there are two barbs at this location, I've called them front and back). From the front barb on the front of the tank to the bottom front port of the bag. Hose that comes off of the "T" at back of hard tank and drain pump connected to bottom rear of bag. Vent line to top port of bag.
Hard tanks fill first, then bag fills and then over the side once bags are full. Works well for me. Bags and tank drain almost completely. Had to drill a 2.5 inch hole through the carpeted cover that hides the through-hulls at the rub rail for the vent line.
PostPosted: Sun May 25, 2014 10:10 am
My rear Sumo 900's don't get air in them at all after the first time I vented them using the valve that came with the sack. When they drain, they drain pretty flat.
PostPosted: Sun May 25, 2014 9:08 pm
We hadn't been getting air in our Ronix 800s but today I had to burp a lot of air out. I think I will be adding a vent as well
