It is currently Tue Nov 11, 2025 1:31 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2, 3, 4  Next
 Post subject: Re: Wetsounds install pics
PostPosted: Mon Mar 24, 2014 7:20 am
I doubt it because these amps run so efficient and have a bunch of headroom. It's more to run the wires back under the amp, and figured if it could circulate some air it wouldn't hurt.
PostPosted: Mon Mar 24, 2014 4:20 pm
That is a seriously nice install, especially all the details!
Mex180
2011 Axis A-20 335ss
PostPosted: Mon Mar 24, 2014 6:27 pm
Thanks mex! Still anxiously waiting to see yours!!! Still have a battery box, sub box and cover, and mount the 420 left to do. Hopefully I'll get it down to just the sub box cover panel by this weekend.
PostPosted: Mon Mar 24, 2014 7:28 pm
Ballast install?
PostPosted: Mon Mar 24, 2014 7:37 pm
Definitely will be doing the ballast. Just not sure when. Getting the system 100% done is priority. Than will probably go with 750 brostocks in rear, and the sumo 950 up front.
PostPosted: Mon Mar 24, 2014 8:47 pm
2 x SD6 amps
1 x jl 1200 amp(powers the sub only)
6 x xs 650 Rgb's in boat
4 x Rev 8's on the tower
1 x JL 12W7AE-3 subwoofer
The subwoofer is under the helm in a box(used the recommended dimensions on the JL site), couldn't go with a 13, wouldn't fit
Fabbed the false front out of fiber glass and used wetsounds 10" rings that I already had. It is attached using 2" industrial Velcro strips.
Had a 3rd sd6 mounted but it was over kill so removed it for the time being, pending my finding some more speakers to install
I wanted a double din head unit so when I made the dash piece I also included a space for the 420.
The best upgrade was the woofer, the sound is amazing.
The battery upgrade is due to being stranded once, that won't happen again!
Mex180
PostPosted: Tue Mar 25, 2014 6:12 am
That looks great mex! Are those 2 sub grilles just for the vent? How does that w7 sound? I had 2 13w7s in my old boat and they sounded pretty good.
PostPosted: Wed Mar 26, 2014 10:30 am
Yeah, the grills are just to vent
Mex180
PostPosted: Wed Mar 26, 2014 1:31 pm
Nice job Mex
PostPosted: Sat Apr 12, 2014 6:26 pm
I finally got my 420SQ and BT mounted in the new CNCd under dash mount. Also built a new sub box tuned to 41 hz using a 4" euro port. I got to listen to it a bit today, and it sounded so much better than the dual slot ported box I had my XXXv2. Now, I just need to build the trim panel for the sub, and turn the badges on the amp. I also still need to clean up some wiring but it's coming together
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 56 guests
