It is currently Tue Jul 08, 2025 11:21 pm
 Post subject: Service Required Engine Fault
PostPosted: Wed Sep 04, 2013 6:25 pm
I was at the lake today on my 2013 A22 was pulling my buddy who was wakeboarding the boat shut off completely, started it back up and it shut off again a check engine light came on highlighted with a group of initials that started with "M" I let the boat sit for about 20 minutes and it didn't come back on..., what could this be? I called my local dealer and they said they aren't sure what could of happened but if its off and the lights aren't on that they will just check it at its next service... Any ideas and/or input is appreciated....
 Post subject: Re: Service Required Engine Fault
PostPosted: Thu Sep 05, 2013 9:45 am
Wow, really could be anything!
If the boat ran fine before and after then it's most likely an electrical issue, just a loose connection or short.
The ECM will log the trouble code so it'll be there for the dealer to see but without any more info or being able to plug in I couldn't tell you much more than that.
Personally I'd avoid running the boat until you find out what the issue is as it could be as simple as a loose neutral safety switch or as bad as a faulty ECM.
Stuff happens but I'm 100% sure that Axis will take care of you on it.
Mike
