It is currently Mon Jul 07, 2025 6:30 am
[ 5 posts ] |
Author |
sprfrkr
Post subject: Replacing Ignition Key Posted: Mon Aug 19, 2013 11:58 am |
Team Axis |
Top |
Dave.Mishchenko
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:21 pm |
Team Axis |
It'll be a 4 position (Accessories - off - run - start).
_________________ 2009 - A22
Top |
AJWest
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:24 pm |
Team Axis |
Anyone else have the ignition/key switch come loose and rotate? Mine's done it a few times.
Top |
sprfrkr
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 12:35 pm |
Team Axis |
Ahh, thanks Dave, I did not realize that. I may just put the acc on the run pole in that case. I have the radio on the acc switch now.
AJ, there is a nut on the back of the switch which you should be able to tighten.
Top |
kyson
Post subject: Re: Replacing Ignition Key Posted: Mon Aug 19, 2013 2:03 pm |
Boater |
Joined: Thu Jul 11, 2013 10:58 am Posts: 49 Location: Austin, TX
Yes- mine was loose and rotating within a couple of hours. I tightened it by hand on the water and it's been ok since.
Additionally, my wedge down indicator was lit while the wedge was up. I had to bend the tab on the transom switch slightly and it's been fine since as well.
H
Top |
[ 5 posts ] |
Users browsing this forum: No registered users and 90 guests |
