It is currently Tue Jul 08, 2025 6:44 am
 Post subject: Speedo/ cruise failure.....help!
PostPosted: Fri Aug 16, 2013 11:48 am
Howdy folks, Speedo is way off....set the cruise control for 11.4 for some surfing and ended up more like 29ish(although it said 11.4) enough for some slalom skiing.....not fun on thee ol' surfboard. I checked the paddle wheel for operation....seems ok (had all paddles and free spinning).......Upon heading back into the dock I revved her up and full plane was only registering 10 or 15 mph....Local shop can't get to it for a week and a half.....I'm pretty sure life will have takin' me into severe depression by then with out my boat.....any suggestions?? I am a gear head and an electrician sooo throw it at me........ THANK YOU!!!!
 Post subject: Re: Speedo/ cruise failure.....help!
PostPosted: Fri Aug 16, 2013 12:16 pm
My friends paddle wheel broke and while he was waiting on new one he use a GPS app for iPhone and set cruise when He go to desired speed on his iPhone.
PostPosted: Fri Aug 16, 2013 3:42 pm
While you are waiting on your dealer put it in RPM mode
PostPosted: Fri Aug 16, 2013 5:38 pm
Can't you go in and adjust or correct the speedo? I know you could on my old MC
PostPosted: Fri Aug 16, 2013 8:54 pm
There is a way to adjust the speedo but I'm not sure. I'm sure someone will chime in on how to do it.
PostPosted: Fri Aug 16, 2013 9:47 pm
Have the info panel on air temp and hold the info/adj toggle down until speedo starts flashing, then use the info/adj to set it, do it with the cruise off, it'll be easier. Also do it while under way, you lose the option to adjust after about 3-5 seconds if you don't touch the button then you have to hold the toggle down again to enter adjust mode. Takes some tinkering to figure it out.
PostPosted: Sat Aug 17, 2013 11:22 am
Walter, what did you use to determine the actual speed.....people are talking about GPS?....Thanks
PostPosted: Sat Aug 17, 2013 11:33 am
I just took my Garmin out of my truck and used it while cruising across the lake
PostPosted: Thu Oct 03, 2013 4:38 pm
Hey Guys, I apologize about not getting back to you all sooner.....You're all frickin rock stars!! I downloaded a speedometer ap on my phone(SMG WAKE).....used Walters reset technique and ta da!!!! Up and surfin' baby!!! :lol: :D
Users browsing this forum: Google Adsense [Bot] and 76 guests
