It is currently Mon Jul 07, 2025 10:30 pm
 Post subject: Stereo won't recognize iPod Touch (Solved)
PostPosted: Fri Jul 19, 2013 9:33 pm
I bought a 4th gen iPod Touch and my stereo doesn't recognize it, when I plug it in I just get USB No Music. It basically doesn't see it as an iPod.
Anybody have any ideas?
Thanks,
Jason
 Post subject: Re: Stereo won't recognize iPod Touch
PostPosted: Sat Jul 20, 2013 8:02 am
What stereo head, factory Sony? Have you tried using aux? Have you used iPod with anything else to verify that it is head unit and not iPod?
I have heard of people trying to use iPod as a storage device ( for transferring files ) and changed some setting that makes it pull up on a computer like a USB don't know if that's your issue or not but it would make it only show data files and not music files
PostPosted: Sat Jul 20, 2013 8:12 am
EDIT ......... Doesn't work with iPod touch, there went my idea. But here is support page I was thinking about
http://support.apple.com/kb/ht1478
PostPosted: Sat Jul 20, 2013 8:59 am
It is the factory CDX-H910UI. The AUX connection works fine but can't change songs from that which was the point of buying the touch.
The touch hooks to my computer OK so I don't think its the cable.
Thanks for the ideas.
Anybody else?
Jason
PostPosted: Sat Jul 20, 2013 9:16 am
In my google searches the only other thing I saw was a hard reset of the iPod ( home button and power button until logo appears) which they claim will not erase data but will reset to normal default. They claimed they didn't eject iPod correctly and corrupted some files. I don't have that head unit so I don't know if you have to eject the iPod or not but it's worth a shot if it hasn't been done other then that I'm out of options good luck
PostPosted: Sat Jul 20, 2013 9:17 am
I used a first get touch for a long time until it committed suicide into a rogue wave, it worked but sometimes would not read if the cable was wet.
PostPosted: Sat Jul 20, 2013 9:53 am
amsugg, I read the same thing about the reset just did it and I'm going to go see if it works now.
Walter, I will double check and make sure the connections are dry.
Thanks, I will report back in a little bit.
Jason
PostPosted: Sat Jul 20, 2013 1:11 pm
The hard reset did the trick.
Thanks everyone for your help.
Jason
 Post subject: Re: Stereo won't recognize iPod Touch (Solved)
PostPosted: Sun Jul 21, 2013 10:52 am
Awesome ......google power
