It is currently Sun Oct 18, 2026 4:10 am
 Post subject: Wetsounds 750W SYN DX2 Amp New Never used w/ pigtail adapter
PostPosted: Tue Jun 09, 2020 9:39 pm
I have a Malibu SYN-DX2-DSP-OE AMP
Brand New in the box never mounted.
OEM pigtail wiring harness adapter
$300obo + shipping
Features:
Wet Sounds SYN-DX Series Marine Amplifiers are designed to be a complete solution for every type of extreme marine application. SYN-DX amplifiers use superior performance circuitry by utilizing Class D Power Supplies. These amplifiers have extreme power output packed inside a small chassis, thermal overload protection, flexible crossovers, extended inputs. SYN-DX amplifiers are a well balanced match for all of the Wet Sounds products.
Technologies:
Microprocessor Controlled
Thermal Overload & Short Protection
Wet Sounds Extensive Crossover Network
Conformal Coated PCB
Stainless Steel Hardware
Matched Power Ratings
Specifications:
Stereo @ 4 Ohms 200 x 2 watts RMS >1.0% THD
Stereo @ 2 Ohms 375 x 2 watts RMS >1.0% THD
Mono @ 4 Ohms 750 x 1 watts RMS >1.0% THD
Frequency Response 20 Hz - 20 KHz
Crossover Range Low Pass 50 Hz - 250 KHz 12dB/Octave
Crossover Range High Pass 50 Hz - 250 KHz 12dB/Octave
Input Sensitivity 0.2 V - 6.0 V
