It is currently Sun Oct 18, 2026 7:24 am
 Post subject: 2011 liquid force melissa hybrid 131
PostPosted: Wed Jun 15, 2016 8:57 am
2011 Liquid Force Melissa Hybrid 131cm
Good functional shape. Previous owner used at the cable park. I cleaned up and repaired some of the base and the wife has been riding it the past few years with no problems. The fins could probably use a bit of TLC (some chips) but would probably be an easy fix with a little epoxy or something. Does not include center fins (they went missing).
Asking $60+shipping
Manufacturer description:
Ms. Marquardt is one of the most versatile female riders in the world, and her board fits her perfectly. Designed to take on any conditions, the Liquid Force Melissa Wakeboard is equally at home behind the boat or down in the sewer runoff in downtown LA during a winch session. It is super smooth, provides a ton of pop and flex at the same time. Step up your game with the new Liquid Force Melissa Wakeboard.
CONSTRUCTION
ABS flex sidewall: Superior strength, a lively spring and soft landings
DISC (Double Inside Single Concave) Hull through center: Softens landings and maintains board speed
ROCKER AND BASE FEATURES
Aggressive, continuous rocker: Smooth, fluid carves with a high arcing pop
RAILS/EDGES
Variable edge rail: Rounded rail in the center for a forgiving feel, sharp rail at the tail for edge control and response
ADDITIONAL FEATURES
Molded-in, warped side fins: Superior tracking hold with minimum drag
SPECS
Ability Level:Intermediate-AdvancedRocker Type:ContinuousFins:Two Molded-In, Warped Side Fins, One Back Center, One Front CenterWarranty:1 YearMore Core Construction:ABS Flex Sidewall // DISC
 Post subject: Re: 2011 liquid force melissa hybrid 131
PostPosted: Tue Jun 21, 2016 5:31 pm
SOLD!!!!!
