It is currently Fri Oct 30, 2026 2:27 am
 Post subject: Axis Surf wake?
PostPosted: Thu Apr 29, 2010 12:49 pm
How are you loading the axis for surf?
The Axis demo boats that I have been out in do not have the plug and play hooked up. I normally just drop a 700 in the rear locker. Anyone else running sacks inside for surfing?
 Post subject: Re: Axis Surf wake?
PostPosted: Wed May 19, 2010 7:21 pm
I got the upgraded fat sacs. I fill the center and then then one side with the plate down. I just bought a 400 pound sac, to replace my 200 for more lean. I'm thinking I can also still use the 200 pound bag, and plum it under one of the rear seats. Everyone has been surfing on the drivers side of the wake. I'm going to take a good look at how I will do it this weekend. Can't wait for my 400lb bag to arrive. Looks like it will be here on Friday. :D
Thanks for hooking me up with the bag Boardstop.com
PostPosted: Thu May 20, 2010 10:24 pm
If you cannot plug that extra bag into the existing system.. I would recommend just buying a tsunami pump, cap and chain quick connect and enough wally plugs to fill the holes in your 200lb bag. Then you can move that bag anywhere you want in the boat. If you want to slide it around or use it on the other side for goofy foot riders it will become a 'mobile' bag with just $110 bucks worth of BFI parts. You can never have enough ballast bags.
