2014 A22 prop shaft coupler http://axiswakeboardboats.com/viewtopic.php?f=16&t=5036 |
Page 1 of 1 |
Author: | eyekode [ Sat Apr 23, 2022 7:26 pm ] |
Post subject: | 2014 A22 prop shaft coupler |
In my quest to replace my leaking dripless shaft seal I have made it to the point where I need to remove the prop shaft coupler. I have removed the vdrive to get better access. I have the nut off but am struggling hard to remove the coupler. Here is my latest attempt: https://photos.google.com/share/AF1QipO ... NVYXFOMnNB I put a prop nut back on the shaft to help center the puller. Then I used a steering wheel puller. I also used penetrating oil and wd40. When all of this failed I heated it up with a heat gun too. Still no luck. In the end I ruined the threads on the steering wheel puller . Any other suggestions? Am I missing something? |
Author: | eyekode [ Sun Apr 24, 2022 7:30 pm ] |
Post subject: | Re: 2014 A22 prop shaft coupler |
So it seems I wasn’t missing anything, just needed more force. I reinstalled the vdrive temporarily and used the output flange as a press. I threaded an old prop nut on to the prop shaft half way. Then put a 10mm socket between the flanges and bought some longer 3/8 bolts to clamp the surfaces together and finally press out the shaft. |
Author: | WayneTuttle [ Sun May 01, 2022 10:26 am ] |
I don't need this yet, but when my 2014 A22 needs it, I will be so glad you shared this! |
