It is currently Mon Apr 29, 2024 8:06 am
[ 4 posts ] |
Author |
mdean4421
Post subject: Front and Center Ballast Issues Posted: Sun Jul 15, 2018 7:43 pm |
Boater |
I had front ballast plumbed in on my 2010 Axis a22. They worked fine all summer, now they don't. They don't drain or fill. I pulled carpet up, popped the little circle plastic piece off the floor to access the hull where the pumps are. Those pumps are under to the left. Pretty hard to access.
It sounds like they don't have power? I don't know how anyone accesses those pumps. Anyone have any ideas?
Top |
mdean4421
Post subject: Re: Front and Center Ballast Issues Posted: Tue Jul 17, 2018 7:02 am |
Boater |
Update: So both pumps actually do make noise like they run, but not pumping in water or out. The back pumps I can take that screw out and unscrew them to make sure nothing is jammed in there. These pumps are mounted in such a hard to access place, what do yall do to see if there is something logged in / diagnose this problem?
Top |
onwi
Post subject: Re: Front and Center Ballast Issues Posted: Wed Jul 18, 2018 7:40 am |
Team Axis |
Joined: Thu Apr 11, 2013 6:19 pm Posts: 199 Location: SE Wisconsin
Fill pumps are attached to the floor. They may be spinning a little but still be clogged. You need to take the screw out and pull the cartridge. Once the cartridge is loose you can inspect or replace. You can do this on the water if you close the ball valve first. Use a screw driver with a magnetic tip. Once you've got a feel for it it really isn't that bad. Drain for the tank is attached to the tank. Drain for the bag, in a PNP set up, is loose. That one I can pull up toward the hatch to look at.
_________________ ________ 2012 A20
Top |
mdean4421
Post subject: Re: Front and Center Ballast Issues Posted: Sun Aug 26, 2018 7:19 pm |
Boater |
Well I figured it out. Dirt dobbers actually built nests inside the hole. The center tank was full, when I cleared the dirt out it drained no problem
Top |
[ 4 posts ] |
Users browsing this forum: No registered users and 41 guests |
