 Post subject: Help wiring amp to rev10's
PostPosted: Thu Feb 23, 2017 3:38 pm
Hey guys,
I'm having an issue with my amp/speakers I'm installing.
I have a ppi 900.4 amp bridged to a pair of Rev10's.
I have a clicking noise with HU volume all the way down. I also have a crackle/pop when turning the amp off. What does this mean?
Also, to bridge it I just to positive to negative on opposite channels, right?
Any idea what settings I should have on the amp?
TIA
 Post subject: Re: Help wiring amp to rev10's
PostPosted: Thu Feb 23, 2017 4:11 pm
Isn't that amp only 4 ohm stable bridged? How are you running it?
PostPosted: Thu Feb 23, 2017 4:36 pm
The amp is only stable 4ohm bridged. That's what the speakers are.
I have both negative speaker wires to the front left negative and both positive speaker wires to front right positive.
Is that not right? How should my speaker wiring hook up to amp?
PostPosted: Thu Feb 23, 2017 8:48 pm
Pretty sure that is a 2 ohm load..
PostPosted: Thu Feb 23, 2017 8:53 pm
Assuming you are hooking up 2 speakers to one bridged channel it is 2 ohm. I don't think u can do 2 4 ohm at 4 ohm load?
PostPosted: Thu Feb 23, 2017 9:35 pm
Ok yeah I found out from searching online that was wrong. I now have it wired positive to front right positive and front left negative for one speaker and the same way for thas other speaker but on the rear channel. According to the wiring diagram online I found that would bridge the 2 front channels to one speaker 450w at 4 ohms and the 2 rear channels to the other speaker 450w at 4 ohms. Sound right?
PostPosted: Fri Feb 24, 2017 12:04 am
Yes that sounds right.. I thought you had 2 speakers on one channel...
PostPosted: Fri Feb 24, 2017 6:17 am
Cool. Appreciate the help. Now I just need to figure out why they make a crackle/pop noise when the amp shuts off.
PostPosted: Fri Feb 24, 2017 8:30 am
No help there man..
PostPosted: Fri Feb 24, 2017 8:40 pm
Where is the HU grounded? Are you running an EQ?
