 Post subject: A22 can be started in gear
PostPosted: Wed Sep 14, 2016 11:12 am
It looks like my neutral safety switch is messed up. Or the previous owner bypassed it? Where should I look for said beast? I assume it is some micro switch inside the shift lever?
My A22 is a 2014 if that helps.
Thanks!
Salem
 Post subject: Re: A22 can be started in gear
PostPosted: Thu Sep 15, 2016 11:14 am
A little more searching and I think the switch is actually located on the transmission. Will check the next time I am on the boat.
