It is currently Sat Nov 21, 2026 3:59 am
 Post subject: Alternator noise in stereo solved
PostPosted: Tue Nov 08, 2016 11:45 am
I have some JL audio amps and am using the stock head unit. I used to have some alternator (I assume?) noise when running. It was very annoying.
The first thing I tried is to clip the ground wire for the head unit and home run it back to the same terminal my amp(s) are grounded to. This solved my issue. Good luck!
