It is currently Sat Oct 24, 2026 2:38 pm
 Post subject: Front and Center Ballast Not Filling - HELP
PostPosted: Tue Jul 17, 2018 8:07 pm
My 2010 is not filling front or center ballast. I don't think it will drain either. When I hit the switch I hear the motors run, but nothing happens. I pulled back the carpet, and popped off the circle access panel to access the pumps. However, the pumps are so far under to the left that I can't get a screw driver in there to open the pumps up to see if they are clogged.
I checked from the underside of the boat on my lift and those holes are not clogged.
Anyone have any ideas on what might be going on? Also, how do people access the pumps?
