It is currently Sat Oct 24, 2026 2:20 pm
 Post subject: Amp For 4 wet sounds rev10’s?
PostPosted: Sun Apr 30, 2017 1:16 pm
So I’m going to be taking off my factory wet sounds Icon 8’s (4 of them will be for sale soon) and installing 4- rev10’s
For amp i was either going to run 1- Wetsounds SD2 or 2 Precision Power PPI900.4’s
I posted the specs below. it looks like i could get 310w per speaker with the SD2 vs 480w with the PPI.
Have any of you done this or any advice? Ive personally used the PPI to power the NVS deviant tower speakers I had on my old boat and it worked great and I’ve read a lot of people run this with wet sounds rev 10
thanks
Cost:
SD2- $1000
PPI900.4- 165 each= 330$ total
SD2
Output Power (RMS) @ 1% 1000Hz 14.4V CEA 2006
Stereo @ 4 Ohms 2 x 400 Watts @ 58A
Stereo @ 2 Ohms 2 x 620 Watts @ 107A
Mono @ 4 Ohms 1 x 1250 Watts @ 108A
Frequency Response 3dB - 8 Hz - 50 kHz
Crossover Range High and Low Pass 30Hz - 300Hz 12dB/Octave
Bass Boost 0-12.5dB @ 27Hz - 110Hz
S/N Ratio (A wtg) >83dB >110dB
Input Sensitivity Low Level 0.2V - 4.1V
Remote Level Range 0 db to -61 db
15.6V Overvolt Protection
PPI
General Features:
Phantom Series Class D Full Range 4-Channel Car Amplifier
RMS Power Rating (14.4V):
4 ohms: 145 watts x 4 chan.
2 ohms: 225 watts x 4 chan.
Bridged, 4 ohms: 450 watts x 2 chan.
RMS Power Rating (12V):
4 ohms: 100 watts x 4 chan.
2 ohms: 150 watts x 4 chan.
Bridged, 4 ohms: 300 watts x 2 chan.
Sonic Electronix Certified Power Rating*:
4 ohms: 149 watts x 4 chan.
2 ohms: 255 watts x 4 chan.
Bridged, 4 ohms: 480 watts x 2 chan.
 Post subject: Re: Amp For 4 wet sounds rev10’s?
PostPosted: Sun Apr 30, 2017 1:54 pm
Alexander on here had an SD2 on 4 Wet Sound towers and it was rediculous loud if he turned up which he rarely did. I couldn't imagine what 480w per speaker would be like.
PostPosted: Sun Apr 30, 2017 3:38 pm
Another amp to think about is the ARC 600.2. I am running this amp to a pair of Rev10s so each speaker is getting 400 watts @ 4ohm. It will power 4 Rev10s @ 300 watts @ 2 ohms. I think that amp can be had for high $600 low $700 range. I know that my 1 pair pair of 10s is LOUD with 400 watts, i couldn't imagine needing another pair unless you wanted to be the loudest boat on the lake. I only wakeboard and the music is loud and clear at any rope length.
PostPosted: Sun Apr 30, 2017 3:53 pm
I have a 900.4 on my one pair of Rev10's and it's loud.
PostPosted: Sun Apr 30, 2017 7:32 pm
Thanks, I hate to run 2 separate amps for the tower speakers but I hate spending 1k for a amp more! Does anyone else have any amps that are good and will power 4 rev 10s
PostPosted: Sun Apr 30, 2017 8:38 pm
My friend has the sd2 and 4 rev10s on his xstar and trust me you will not be disappointed.
PostPosted: Sun May 07, 2017 8:04 am
I used the SD2 on my 4 Rev 10s too... no way you can go wrong with that choice.
