Ballast set up for 2014 t22 http://axiswakeboardboats.com/viewtopic.php?f=15&t=4112 |
Page 3 of 3 |
Author: | onwi [ Thu Apr 06, 2017 7:15 am ] |
Post subject: | Re: Ballast set up for 2014 t22 |
@buffaxis - you can either drill a new hole in the bottom of the boat or use the existing t-handle plug location if you are willing to lose that drain spot. Then use a reversible pump so the water flows in and out at that spot. The question I have is where you would bring the hose through in an A series boat. There is no recessed portion of the bow sidewall, so there is no easy place to hide and then retrieve the hose from. Anybody with an A-series have a picture or idea on how they managed this? |
Author: | steveA20 [ Thu Apr 06, 2017 7:31 am ] |
buffaxis wrote: steveA20 wrote: Here is the CAD. I installed one in my 16 A20, I'll test it out Saturday. how did it work? thanks for the cad photos Worked great! Perfect fit and I love that the fill and vent ports are at the tip of the bag and go up into the hollow spot of the bow, no crushed lines or popped up cushions [emoji106] |
Author: | buffaxis [ Sat Apr 29, 2017 1:50 pm ] |
that is great thank you. |
Page 3 of 3 | All times are UTC - 6 hours |
