It is currently Sun Nov 15, 2026 9:17 am
 Post subject: Sub woofer stopped working
PostPosted: Tue Aug 20, 2013 8:26 pm
Any troubleshooting tips for a sub woofer that stopped working?
 Post subject: Re: Sub woofer stopped working
PostPosted: Mon Sep 09, 2013 8:40 pm
do you have a volt/ohm meter?, you can start by checking the sub resistance and the output of the amp, my stereo recently started acting retarted and it ended up being a bad battery, i'm just glad I had a spare I could switch to and get back to the ramp.
PostPosted: Thu May 01, 2014 8:40 pm
Walter this happend to me last year. I pulled the sub and there was a jumper on the back of it that fell off. Quick fix!
store.kultureva.com
Poor Gate Equiped
PostPosted: Sat May 10, 2014 8:56 am
This happened to me too ended up being a bad amp you can also move the sub output wire to another channel that you know is working, takes a couple seconds and you don't have to pull your sub out.
