It is currently Sat Oct 24, 2026 2:22 pm
 Post subject: Wakeye Gopro mount
PostPosted: Mon Apr 27, 2015 8:12 pm
I was looking at the Wakeye Gopro mount that mounts on the tower rope and follows you as you wakeboard. I often wakeboard with my wife so I thought it would be a nice way to video ourselves.
Has anyone used it?
Looks like there are two sizes but my boat is on order so I can't measure which size, just curious if anyone has one and any input?
thanks
2015 T23
 Post subject: Re: Wakeye Gopro mount
PostPosted: Mon Apr 27, 2015 10:13 pm
Cool idea, but having a GoPro, it isn't designed for long distant shots. I could see this used for surfing since you are much closer to the boat.
2014 A24 w/ LS3
PostPosted: Sun May 31, 2015 12:31 pm
Here is an option.. rope mounted..
PostPosted: Sun May 31, 2015 3:59 pm
If your using a gopro to simply critique youself it will work just fine. The gopro films at 1440p 2k and 4k, so zooming in has become more practical with the higher resolutions. But I would not use it if your trying to make a quality edit video.
PostPosted: Mon Jun 08, 2015 12:46 pm
I agree with robert. I just throw the gopro on the tower 1080p 60FPS NFOV and it gets everything you need for critiquing yourself while wake boarding. Now if you are trying to make a sweet edit or something, it may be a little plain. Narrow field of view is important when doing this because if you keep it in wide, everything seems way to far away.
2014 A22
