 Post subject: 2012 A20 PNP Ballast... the real deal?
PostPosted: Mon Jun 18, 2012 8:31 pm
So I want to surf, I've got a 2012 A20 with PNP set up. I've been reading up a bit and it seems like a lot of people having difficulty with the additional bags. I really don't want to have to install something and keep on having to mess with it every time I take the boat out. This is also my family boat. Unless Axis has changed something for 2012 this is what I've gathered....
1) Buy the Fly High for the front as it has it's own pump and plug and play is pretty straight forward and bulletproof.
2) Buy a sac for the rear with a tsunami pump and save the hassle and extra $$$
Thoughts?
store.kultureva.com
Poor Gate Equiped
 Post subject: Re: 2012 A20 PNP Ballast... the real deal?
PostPosted: Tue Jun 19, 2012 5:50 am
I use the tsunami and it work great and it fast....
PostPosted: Tue Jun 19, 2012 8:59 am
We only use a rear sac for surfing on the surf side so I only need 1 sac for the rears. I put quick connects ends on the bag fill & drain tubes on that side. When we arent surfing & using the sac I have a quick connect hose I can put in between the bag fill/empty tubes so it goes directly into the hard tank like it did from the factory. takes about 2 seconds to hook up & disconnect.
I did the tsunami pump thing for my 750 bag on top of the hard tank but I didnt feel like messing with a pump anymore. The tsunami pump does fill & empty fairly quickly though. We dont surf that often so I think my option works best for us when we want to wakeboard & just fill the hard tanks only.
PostPosted: Wed Jun 20, 2012 8:51 pm
Went out with a buddy today and brought some sacs for me. We probably had about 400lbs in the surf side locker along with the stock hard tank and then about 350lbs on top of the front seats with the center filled and no wedge. The surf wake was great! Had a really fun time! I'm gonna buy the front plug and play bag and a rear 750 with a tsunami pump and call it a day. Now I just gotta find $700.
store.kultureva.com
Poor Gate Equiped
