It is currently Fri Oct 30, 2026 11:00 am
 Post subject: Warranty question
PostPosted: Wed Jul 04, 2012 9:18 pm
If I bought an Axis used, would it still be under warranty? How does all of that work if you are not the original owner?
 Post subject: Re: Warranty question
PostPosted: Thu Jul 05, 2012 5:48 am
I believe only the drive train warranty is transferable on an Axis. You have to have indmar certified mechanic do an inspection. The cost is around $400 depending on what the mechanic charges for the inspection. I would check all of this info with a dealer because I've never actually done it.
