It is currently Mon Sep 28, 2026 1:30 pm
 Post subject: high pitched noise
PostPosted: Mon May 21, 2012 10:31 am
Hi everyone.
We have axis A22 Vandall edition 2011. When the engine is about 20-25, there is a extremely loud high pitched noise from the engine.
when i go faster it goes away.
unfortunately, we ride at 20-28 quite abit.
the noise is so loud , it almost intolerabel.
Any feedback would be appreciated.
Thnks
 Post subject: Re: high pitched noise
PostPosted: Mon May 21, 2012 10:37 am
what prop do you have? I have a similar noise at lower rpm. i think its from the transmission ( i don't know correct term for boats) i switched to a different prop and mine got better. its possible its a normal characteristic but i would check trans fluids just to be safe
PostPosted: Mon May 21, 2012 10:41 am
the prop is factory installed.
was your noise extemely loud?
PostPosted: Mon May 21, 2012 11:21 am
Is the noise kinda like a whistle sound...almost like a supercharger in a car? If so, it's just the v-drive. Haven't heard yours so can't say if it's louder than others though.
PostPosted: Mon May 21, 2012 11:45 am
Make sure the cover under the bench seat is closed up snug.
PostPosted: Mon May 21, 2012 12:32 pm
mine was loud enough to make me check fluids. i was slightly paranoid as it was the first trip out so i was paying to much attention to every noise. but i check fluid and everything was fine so i just figured it was normal. you can't hear it once you get up to speed and now that i changed prop i barley hear it at all
