It is currently Mon Sep 28, 2026 7:03 pm
Fiveflat
Post subject: Coolant temp warnings LS3 Posted: Mon May 21, 2012 8:11 am |
I don't know how many other LS3s we have here but I have about 15 minutes of 5mph and idling before I get out of the marina. Almost every time I pull it out, I get coolant temp warnings just before I'm out of the 5mph. It's up at 185* Once I speed up, it'll drop down to 165-170* and it's good.
Anyone else?
_________________ Axisowners 2012 Axis A22
nastya20
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 9:19 am |
Does this happen when you go back in as well, or just on way out?
Fiveflat
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 9:32 am |
Just on the way out.
Walter
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 11:07 am |
The warning buzzer needs to be raised to 200deg, it sounds like its just coming on when your thermostat is opening. Probably have to get the dealer to put in a 160 instead of the 180. Or reflash the computer to raise the warning temp.
Dave.Mishchenko
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 11:18 am |
Joined: Fri Aug 20, 2010 5:21 pm Posts: 336 Location: Vancouver
Fiveflat
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 12:01 pm |
Thanks, didn't think to check the bucrew site.
Sounds like I fit right in with those others. I'll check with the dealership tomorrow when they open.
Chattwake
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 12:18 pm |
Fiveflat
Post subject: Re: Coolant temp warnings LS3 Posted: Mon May 21, 2012 12:20 pm |
Yours is quite a bit newer and maybe has that booster pump kit already installed?
armyparke
Post subject: Re: Coolant temp warnings LS3 Posted: Fri May 25, 2012 7:52 am |
| Newbie |
I have almost 200 hours with the similar situation to get out of the marina. Mine stays between 155-158.
Fiveflat
Post subject: Re: Coolant temp warnings LS3 Posted: Fri May 25, 2012 8:51 am |
Last time I came out of the marina (Wednesday) I made an effort to hustle out and I beat the alarm... Got up around 170 before I made it out of the 5mph but it cooled down as soon as I took off.
Users browsing this forum: No registered users and 61 guests |
