It is currently Fri Sep 25, 2026 6:48 pm
 Post subject: Rear Ballast Filling
PostPosted: Sat Apr 14, 2012 8:18 pm
Ok I seem to be having an issue with my rear tanks filling. Went out today and when I selected the right rear it filled the left, so I thought maybe it is backwards so I drained it and selected left and it again filled the left. I normally fill them together and it works fine, can anyone shed some light on that one for me. I have always thought that when you fill the right it is driver side. Is that Correct
 Post subject: Re: Rear Ballast Filling
PostPosted: Sun Apr 15, 2012 8:47 am
the right tank should be the one on the drivers side. do you have bags hooked up too? I would check the plumbing to make sure the hoses were hooked up right. Did you notice when you fill them together if the left side fills first then the right? If hoses are hooked up correctly then I would look at the wiring to make sure the switches aren't wired to the same pump. Good luck.
PostPosted: Tue Apr 17, 2012 9:34 pm
Both should be independent...separate pumps for filling. Even without bags, I'd use a fake a lake or go on the water with a container and friend. Trace and remove the hoses one by one and see. Right is behind driver side like wvidal said.
PostPosted: Wed Apr 18, 2012 8:39 pm
I have not added any bags yet Im still deciding on with one to get not sure if I want the standard 400lb sacs in the rear or 750lb.
Users browsing this forum: No registered users and 86 guests
