It is currently Mon Oct 26, 2026 8:10 pm
 Post subject: 2020 axis t22 overheating
PostPosted: Sun Mar 29, 2020 5:03 pm
Our Axis T 22 M5Di motor over heated today. Dealer said it would be 2 to 3 Weeks before they could get to it. We pulled the intake screen and checked under the boat at the intake grate and it’s clear.
The antifreeze when the boat was hot was half full but when cooled
off was emptied. Where is the impeller located and the thermostat? Will fill with correct 50/50 antifreeze and want to check impeller and thermostat if can locate them. Pics will be appreciated.
 Post subject: Re: 2020 axis t22 overheating
PostPosted: Thu Apr 09, 2020 6:13 am
There was a thread over on another forum about this. Sounded like the coolant tank had a massive air pocket and that wasnt letting the coolant flow. Also, someone had an issue with the impeller being bad (brand new boat).
