It is currently Thu Oct 29, 2026 11:18 am
[ 2 posts ] |
buffaxis
Post subject: Acme 2773 prop vs 2419 Posted: Fri May 03, 2019 5:34 am |
I have a 2014 t22 with a 2419 that needs repair.. I called acme and they recommended a 2773 prop its the same diameter of the 2419 which is a 15-12 and the 2773 is a 15-13.
does anyone run the 2773 on their boat?
They mentioned that the 2419 might be too aggressive and run at a higher RPM / and not needed I have the plug and play ballast with 800 bags in the rear...
any thoughts would be great..
80AMT23
Post subject: Re: Acme 2773 prop vs 2419 Posted: Sun May 05, 2019 4:09 pm |
It's up to you whether it's too aggressive, the 2773 will run lower RPM than the 2419 but it will also not spin up the motor as high of RPM which may mean you lose power getting on plane, but I found the 2419 put the RPM way to high out of the hole and it went past the peak powerband of the engine. A lot of people like the 2773 as a good balance.
_________________ 2016 Axis T23 w/410 ACME 2249 prop (WakeMakers 825# rear kit, WakeMakers ExactFit bow bag)
[ 2 posts ] |
Users browsing this forum: No registered users and 59 guests |
