To V-Drive fluid change or not to change. http://axiswakeboardboats.com/viewtopic.php?f=14&t=4576 |
Page 1 of 1 |
Author: | Skibum [ Thu May 17, 2018 4:43 pm ] |
Post subject: | To V-Drive fluid change or not to change. |
The Boat: 2015 A-22 w/5.7l The Situation: When I was at my local dealer picking up a part a few days ago, he tried to sell me on a v-drive fluid service for about $150. When I got home, I read the manual and everything I saw indicated that as long as the fluid level is within spec, it does not require a fluid change. The Question: Does it need to be changed or is he just trying to take my $150? |
Author: | steveA20 [ Thu May 17, 2018 7:59 pm ] |
Post subject: | Re: To V-Drive fluid change or not to change. |
Skibum wrote: The Boat: 2015 A-22 w/5.7l My dealer does it as part of the 25hr service and doesn't touch it again.The Situation: When I was at my local dealer picking up a part a few days ago, he tried to sell me on a v-drive fluid service for about $150. When I got home, I read the manual and everything I saw indicated that as long as the fluid level is within spec, it does not require a fluid change. The Question: Does it need to be changed or is he just trying to take my $150? Sent from my SM-G955U using Tapatalk |
Author: | pilotflying [ Fri May 18, 2018 1:03 am ] |
Same here. As long as the fluid level is good and the fluid is clear my dealer won't touch it. |
Author: | Skibum [ Fri May 18, 2018 9:20 am ] |
Thank you! I'll check the level/color and go from there. |
Author: | granddaddy55 [ Tue May 29, 2018 5:34 pm ] |
In a high hours boat it’s considered to be an annual service you perform yourself easily and cheaply , much cheaper than a more frequent oil change interval |
