It is currently Sat Nov 07, 2026 2:10 am
 Post subject: Saltwater
PostPosted: Thu Jan 26, 2012 11:44 am
Just wondering if anyone has any experience with the salt water series Axis has.
I'm always in straight up salt water or brackish here in Jacksonville, FL.
Thanks!
 Post subject: Re: Saltwater
PostPosted: Thu Jan 26, 2012 3:30 pm
Im in VA Beach. My boat will never see fresh water. The boat will last as long as you take care of it and flush it. I have known plenty of people here who have opted out of closed water cooling system engines. Some parts still need flushed with fresh water. Someone can chime in on that part. I know only about half the motor is closed off.
Gibby
2011 A22 Vandall
PostPosted: Thu Jan 26, 2012 6:29 pm
Haha I'm just the opposite, my boat will probably never see salt water but I would like to convert it just for the hell of it. I would like to see a few pictures of the engine and hoses and heat exchanger in the salt series, I found a conversion kit that changes just the block only, not exhaust, to fresh water cooling for about 850$. I called Indmar and they want 2500-3000 for their kit but it includes the exhaust manifolds. I would like to keep antifreeze in the engine block just so it will last longer and the heater will work much more efficient too, I've also read some things about the fuel consumption and emissions being better with the temp at the correct range but that is just an added perk if you ask me. Put up some good pics if you guys have any!!
PostPosted: Tue Jan 31, 2012 7:14 am
Gibster, how long have you had your boat? Any negative impact from salt water thus far?
