Oil Change Kit http://axiswakeboardboats.com/viewtopic.php?f=14&t=4392 |
Page 1 of 2 |
Author: | Lcannon13 [ Wed Sep 06, 2017 2:27 pm ] |
Post subject: | Oil Change Kit |
Anyone have any suggestions on what to pick up to do my own oil changes? I have been looking around at a few extractors, but figured you all would have a better idea as to what is best. Thanks! |
Author: | vanamp [ Wed Sep 06, 2017 4:46 pm ] |
Post subject: | Re: Oil Change Kit |
One of these and hit your local hardware store for a fitting that will thread onto your drain tube. https://www.amazon.com/gp/aw/d/B000GU0M ... BK3C7LO58P Makes things a breeze Sent from my SM-G930V using Tapatalk |
Author: | shawndoggy [ Wed Sep 06, 2017 6:28 pm ] |
Hey bud I dropped some knowledge on your partner! I have one like vanamp linked and if I were doing it over again, I'd get a mighty vac or go all-in and get the electric jabsco pump/bucket setup (the Cadillac of extractors). |
Author: | Wilbur [ Sat Sep 09, 2017 12:02 pm ] |
Anyone every use a drill motor style pump like this http://www.homedepot.com/p/AquaPro-Dril ... ZAodzl8ChA |
Author: | vanamp [ Sat Sep 09, 2017 2:32 pm ] |
The drill style pumps would not be strong enough. I just used one recently to drain a tank and they are wimpy and very little suction. Sent from my SM-G930V using Tapatalk |
Author: | dustinjean [ Sun Sep 10, 2017 5:34 am ] |
I have a hand pump one like the pela but after seeing that jabsco electric I'm gonna have to order one Sent from my SM-G900V using Tapatalk |
Author: | Lcannon13 [ Mon Sep 11, 2017 10:58 am ] |
Thanks everyone. Got it all taken care of this weekend. Used this extractor https://www.amazon.com/Transfer-Extract ... +extractor worked like a charm. Just used a home depot 5 gallon paint bucket to catch all of the oil. |
Author: | JohnnyK [ Wed Oct 04, 2017 9:38 pm ] |
vanamp wrote: One of these and hit your local hardware store for a fitting that will thread onto your drain tube. https://www.amazon.com/gp/aw/d/B000GU0M ... BK3C7LO58P Makes things a breeze Sent from my SM-G930V using Tapatalk I just ordered one of these. Do you know what size fitting you used for this? The boat is 4 hours away, so I just want too make sure I have the right things to winterize Sent from my iPhone using Tapatalk |
Author: | boardjnky4 [ Thu Oct 05, 2017 8:03 am ] |
1/2" NPT Female to Barb |
Author: | saberworks [ Fri Oct 06, 2017 9:17 am ] |
shawndoggy wrote: Hey bud I dropped some knowledge on your partner! I have one like vanamp linked and if I were doing it over again, I'd get a mighty vac or go all-in and get the electric jabsco pump/bucket setup (the Cadillac of extractors). Just wanted to say thanks for the suggestion. I sprung for the jabsco one linked here and it worked very well. I didn't bother threading anything onto the end of the drain hose on the engine, I just ran the clear tube that came with the kit up through the drain hose and sucked everything out that way. I then ran the clear tube down the dipstick hole and got nothing further out of it. It did take about 15 minutes to pump the (warm) oil out, but I had other things to do while it was running. Didn't spill a drop and it was super easy to pour the oil from the bucket into the "new oil" containers once I was done filling the boat. I had previously bought and tried a mityvac one and I must have had a defective unit because it required me to manually pump the entire time to get anything to suck out (threw it in the garbage). The electric pump was a definite step up. |
Page 1 of 2 | All times are UTC - 6 hours |
