It is currently Tue Jul 28, 2026 1:42 am
[ 6 posts ] |
gibbs114
Post subject: Drain Plug Posted: Wed Dec 14, 2011 5:17 pm |
On the A22 is there a drain plug under the boat and if so where is it located?
Dave.Mishchenko
Post subject: Re: Drain Plug Posted: Wed Dec 14, 2011 5:52 pm |
No - just at the back. On the bottom mine has 3 inlets for ballast, one of the engine, the speed control paddle, and a plate.
_________________ 2009 - A22
Johnnydefacto
Post subject: Re: Drain Plug Posted: Wed Dec 14, 2011 6:25 pm |
gibbs, not for sure, may just be on 2011 and up, but there are 2 drain plugs. one rear one at bottom of transom that I am sure you are aware of, and then one t-handle plug in the middle of the boat where the front and middle ballast pumps are. to access this t handle plug ( which is the only one I use when I drain) you pull your carpet back from the front by the driver seat. there is 6" hole with a black cover. this hole allows access to your 2 fill pumps and 2 empty pumps for the ballast and pnp bag. You can see the 4-5" long t handle, or just reach in towards the port side and feel for it.
Walter
Post subject: Re: Drain Plug Posted: Wed Dec 14, 2011 6:32 pm |
My 2010 has one in the far back between the exhaust outlets that I have never used and the T handle just below the driver seat where Johnny described, the T handle is the lowest point in the hull and gets all of the water out fast, the 2009 that my dealer took me out for a test ride in had its drain below the cover under the skybox seat right next to the transmission
gibbs114
Post subject: Re: Drain Plug Posted: Wed Dec 14, 2011 6:54 pm |
Thanks for the info, mine is a 2011 so I will check out the T handle. The hole the is right in front of the shark fin seams be be threaded so I thought it was a plug.
Dave.Mishchenko
Post subject: RE: Drain Plug Posted: Wed Jun 27, 2012 10:40 pm |
I took a better look and mine (09) has two up there - each side of the fin. Sorry about the misinformation.
Sent from my SGH-i917R using Board Express
Last bumped by Dave.Mishchenko on Wed Jun 27, 2012 10:40 pm.
[ 6 posts ] |
Users browsing this forum: No registered users and 52 guests |
