 Post subject: Heat coming from dash
PostPosted: Tue Jul 04, 2017 8:15 am
I am getting a lot of heat blowing on me from dash after a few minutes of driving. I have a heater and putting out heat like heater is on. When turn on heater it just blows out stronger. Any help on what may be going on?
 Post subject: Re: Heat coming from dash
PostPosted: Wed Jul 05, 2017 2:53 pm
Is the heater vent under the dash open or closed?
2017 T23
2007 Malibu VTX (Sold)
PostPosted: Wed Jul 05, 2017 3:51 pm
A small radiator (heater core) is located under the dash. The engine pushes hot exhaust water through a hose to the heater core. This process is done regardless if the heater is on or off. When you turn on the heater, it turns on a fan that pushes air through the radiator and through the vent hoses. Chances are, everything under the dash is running as normal. If you hear water flow from under there, it means you have a busted heater core. Don't ask me how I know all of this.
PostPosted: Thu Jul 06, 2017 7:37 pm
Thanks
And yes all vents are closed
