 Post subject: AUX Stero Jack Location?
PostPosted: Tue May 09, 2017 3:18 pm
I have just completed a RGB LED light install, and trying to locate the AUX jack. The brain/RGB controller has a AUX jack where you can connect it to the head unit to sync the music with the flashing led lights. Problem I'm having is I cannot locate where the AUX jack is located. any help would be appreciated.
 Post subject: Re: AUX Stero Jack Location?
PostPosted: Tue May 09, 2017 3:48 pm
the aux jack is an input. If you hook your controller into a jack you are supposed to use to send music to the headunit, how is the controller going to do anything?
Seems to me you'd want to split off of the full range RCAs heading to your cabin speaker amp.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 48 guests
