It is currently Fri Oct 30, 2026 4:39 am
 Post subject: Transmission locked up?
PostPosted: Fri Nov 25, 2016 3:18 pm
I was surfing my '16 A20 (110 hrs) this afternoon and all of a sudden the engine quit without any warning. No lights, no beeps, nothing. I thought maybe I had hit something but where we were on the lake there shouldn't have been anything to hit and we were in about 20 feet of water. I turned off the key, waited a couple minutes going over what could have happened with a couple knowledgeable passengers and decided to try to start the engine. It fired right up without any issue. No problems with temp or oil pressure. Smooth idle. When I went to put the boat in gear the engine quit again. I immediately thought something might be wrapped around the prop/driveshaft. I started the boat again and tried to put it in reverse. Again it died immediately. We got towed back to the dock and put the boat up on the lift. I couldn't see anything wrapped around any part of the running gear. I tried to spin the prop by hand and couldn't move it. I checked the engine oil and it was good. I checked the short yellow transmission dipstick and saw fluid on it so I believe that should be good too. I checked the bilge area around the engine and didn't see where any fluids had leaked out.
Any ideas what might have caused the transmission to lock up?
I will bring the boat to the dealer next week but thought I'd run this by the board and see if anyone has experienced anything similar.
 Post subject: Re: Transmission locked up?
PostPosted: Fri Nov 25, 2016 4:40 pm
Any chance the safety switch got pulled? One that's on the red springy lanyard and is supposed to be attached to driver?
Did you check v-drive fluid? It's under the rear seat, you slide the rear seat forward and pull the fiberglass step out.
PostPosted: Fri Nov 25, 2016 5:38 pm
Definitely not the safety switch. The boat engine stopped due to the prop/drive shaft/transmission/v-drive locking up. I didn't remove/replace the key or the move the safety switch and was able to fire the engine right back up.
I checked the fluid in the v-drive and it appeared to be at the correct level and it is a reddish color.
I do have a question though - are the transmission and v-drive one single unit or are they separate components?
PostPosted: Sat Nov 26, 2016 6:25 am
They're separate components Todd. Check fluids in both.
PostPosted: Sat Nov 26, 2016 6:32 am
As said they are separate and there are 2 dipsticks, with 110 hrs have you had the fluid changed in them?
PostPosted: Sat Nov 26, 2016 8:52 am
Has Anyone else received this in the mail? Apparently there could be a problem with some losing V-Drive oil. My dealer had no idea until I showed them. Let me know if anyone needs to see more.
Zoom in to read.
PostPosted: Sat Nov 26, 2016 4:57 pm
I didn't get that letter, but when I went in at 25 hours my dealer said my v-drive fluid was low. But there was no real indication that it was leaking; nothing of note in the bilge.
PostPosted: Sat Nov 26, 2016 5:19 pm
I got it a few weeks ago.
PostPosted: Sat Nov 26, 2016 8:50 pm
Thanks Tom. I'll try to find the other place to check the transmission oil when I get back in the boat.
I didn't receive that letter. I plan to contact my dealer on Tuesday and drop the boat off there when they can check it out. I'll keep you all updated on what they find.
PostPosted: Wed Nov 30, 2016 3:08 pm
I found them both and both have fluid in them.
I dropped the boat off at ProMarine today. They're all interested in knowing what happened, as am I. I just hope I can get the boat back before Christmas so we can get in a Christmas Shred Session :) I'll let you know how it turns out.
