It is currently Fri Oct 23, 2026 1:32 pm
 Post subject: High pitch squeeling noice coming from levorsi shifter
PostPosted: Sat Jun 18, 2016 1:12 am
guys
just a quick one
does anyone have the same issue when going at speed
it seems like a high pitch squeeling noise, but then goes as I lower the speed
it seems to be coming from the shifter (throttle) but im not 100% sure
I didn't know if it might be some strain on the cable?
any ideas?
I have the 2015 Axis A22 Liquid Force Edition
Any help appreciated
my boat is going in for service this week so any guidance I can give would be great
cheers
Lyndon
2015 Axis A22
409HP Engine Upgrade
And a few other options!
 Post subject: Re: High pitch squeeling noice coming from levorsi shifter
PostPosted: Sat Jun 18, 2016 7:58 am
Next time you hear it, hit the fill on your front ballast one at a time. I've discovered that I have a whine/squeal noise but it's the fill ballast being forced at a certain speed.
PostPosted: Sat Jun 18, 2016 8:02 am
my center ballast pump also squeals
PostPosted: Sat Jun 18, 2016 8:24 am
Same here.. only one that does it.
PostPosted: Sat Jun 18, 2016 8:58 am
Is it the pump or the anti siphon loop under the dash for the center tank? I've heard it also but couldn't figure out which of the two it was.
PostPosted: Sat Jun 18, 2016 9:04 am
I really don't know.. it when I turn it off it makes the noise.
PostPosted: Sat Jun 18, 2016 9:46 am
Same here as soon as you turn it off, my wife thought the pump had seized so she drained some out and refilled it and it did it again so we just expect it every time now
PostPosted: Sat Jun 18, 2016 1:43 pm
It's the anti siphon valve releasing the air after the pump shuts off.
