It is currently Sat Oct 24, 2026 6:28 am
 Post subject: Oil Change
PostPosted: Fri Apr 29, 2016 5:06 pm
Hey people. I did my preseason oil change yesterday. I ran the tube out the rear drain plug hole and uncapped the line. Even with the oil fill cap off, the oil just trickled out. Is this normal? Have any of you tried the pump it out through the dip stick tube? All input appreciated.
 Post subject: Re: Oil Change
PostPosted: Fri Apr 29, 2016 5:26 pm
Omg it sucks terribly! Same thing happened to me and couldn't really get it all the way out of the drain hole. There has to be a better way. Almost need a pump and with a female connection to the drain hose. I used a pump for trans fluid and that worked well.
PostPosted: Fri Apr 29, 2016 5:28 pm
And I was going to put it down the drain tube but I couldn't get it passed the senond bend. I have the crusader 350 in my 15 t22. I am curious to know how others have done it
PostPosted: Fri Apr 29, 2016 5:32 pm
That is how I drain my oil. I plan it to were I just let it drain all night, then finish up the next day.
PostPosted: Fri Apr 29, 2016 5:46 pm
I pump it out of the dipstick tube with the same pump I use for the vdrive and trans fluid. Takes around 15-20 mins if I get a good flow going.
PostPosted: Fri Apr 29, 2016 9:18 pm
Thanks for the replies. Just wanted to know if I was having an issue or if this is the norm. Went and bought a Jabsco pump today and will try the dip tube next time, or attach it to the factory drain tube.
PostPosted: Sat May 07, 2016 12:28 pm
Warm oil (don't recommend hot!) drains/sucks much easier.
PostPosted: Sun May 08, 2016 4:47 am
Attach a pump to the threaded drain hose. It's a 1/2" NPT fitting, you can get it at Home Depot.
PostPosted: Sun May 08, 2016 8:08 am
Be very careful about putting anything down the dipstick tube. You will hate life when your extractor tube breaks off.
PostPosted: Mon May 09, 2016 7:10 pm
+1
Makes no sense to do it this way.
Just use this fitting on the drain hose and attach it to your choice of pump.
Anderson Metals Brass Hose Fitting, Connector, 1/2" Barb x 1/2" Female Pipe https://www.amazon.com/dp/B000BPECSK/re ... mxbYDXQ0P1
