It is currently Sat Oct 24, 2026 7:28 am
 Post subject: Rear Pluy n' Play 2013 A22, Late 2012 Build
PostPosted: Mon May 09, 2016 3:07 pm
Hey all -
I know I've read through many of the plug and play install scenarios throughout this forum, but I wanted to verify some things before I started my project. I have a 2013 year model, specifically a late 2012 build. From what I understand, there are a few versions of the rear plug n' play that was put out in 2013 and mine seems to be one of the in between options prior to the final 2013 version.
Here's what I think I have....
Each rear tank has single hard plastic wye mounted behind rear seats, with one hose going down into the hard tank, and one hose coming from the pump.
There is a spare hose in the rear of each compartment (rear drain of bag into hard tank), and there are two connections at the top of each hard tank (One from the hard wye, and the other I'm not sure where it goes).
I'm assuming to complete my install, I will need to;
1. Disconnect supply hose from the hard tank that comes from the hard plastic wye.
2. Take hose that was disconnected and this will now be supply into top of bag.
3. Hook up hose that's already in rear of compartment as the rear drain line.
4. ADD a hose from the front bag drain, into the connection of the hard tank that I disconnected the new supply hose from.
Am I finished here.... or is there something I'm missing?
Let me know if anyone has experience with the 2012/2013 installs or there is another thread I should reference.
Thanks!
2013 A22 // Mission Gate // 950 Arrow // 900 Rear Sumo's // Acme 2419
