It is currently Sun Aug 16, 2026 12:05 pm
 Post subject: No RPM Cruise Controll with GPS?
PostPosted: Thu Aug 13, 2015 3:34 pm
2015 T22. PCM 350 Motor.
When I purchased the boat my cruise worked in both RPM and GPS mode. Last weekend the boat would not engage the cruise when I flipped it to RPM mode and would only show the set point and "PULL" in lieu of the live rpm readout on the Cruise display.
The actual RPM needle still functioned properly but the digital readout for the RPM under the cruise control setting only showed "Pull" and did not read out the live Rpm figures when the cruise was switched into RPM mode.
I took the boat to the dealer and they are being told by Malibu that the RPM mode will not work as my boat is equipped with the GPS cruise. Dealer is telling me they replaced the Gauge and the problem is still there.
Does this seem correct to anyone? I'm calling BS as I had previously been able to use both the RPM and GPS functions on the cruise control.
Does not see like the explanation from Malibu boats is accurate..
Does any one have any experience with this?
If you have GPS on your Axis are you able to run the cruise in RPM mode?
Any help would be appreciated.
Users browsing this forum: No registered users and 84 guests
