It is currently Tue Jul 28, 2026 8:31 am
 Post subject: lock for boatmate trailer?
PostPosted: Mon Apr 23, 2012 9:03 pm
Hey all,
I've got the single axle trailer that came with my A20, but I store it in open facility (no room in the garage), so I'd like to make sure joe schmoe can't just hook up to my trailer and tow it away. Anybody know where I can get my hands on a lock for my trailer?
NOTE: It's the UFP A-60 2" Ball model, by TrailerBuddy
2011 A20
 Post subject: Re: lock for boatmate trailer?
PostPosted: Mon Apr 23, 2012 9:11 pm
otownwake wrote:
Hey all,
It should have a swingaway hitch, right? If so, take out the pin. You can still lock it, Walmart carries long shackle brass padlocks that are perfect for trailers: http://www.walmart.com/ip/Brinks-Padlock/16781203
PostPosted: Tue Apr 24, 2012 1:20 pm
I usually just swing out the trailer tongue and put a lockable trailer hitch pin in place.
PostPosted: Wed Jun 27, 2012 10:28 pm
I use a tire lock like this one and lug nut locks to keep the tires on.
I'm also thinking of getting a prop lock to make sure it doesn't walk off.
PostPosted: Thu Jun 28, 2012 6:55 pm
If I leave mine out somewhere this is what I do. I also drilled out the hole on the coupling on the trailer tongue so a lock will fit thru it. So if I keep it hooked to my truck I can lock it so no one can unhook it and swing it to hook up to there vehicle. Also u can put the hitch in the locked position and lock it to keep someone from hooking up to it.
PostPosted: Fri Jun 29, 2012 2:28 am
that is exactly what I do.
Users browsing this forum: Google [Bot] and 36 guests
