It is currently Mon Oct 26, 2026 2:07 pm
 Post subject: Found my water leak yesterday :D
PostPosted: Wed Nov 05, 2014 6:44 pm
I have a dripless shaft seal, but it started leaking really bad over the last year or so, got it fixed mid season but I still had a water leak. 30 minutes into riding the auto bilge would turn on, and I always had a couple inches of water at the center T handle plug when pulling the boat out. So i decided I would wait til winter to spend some time on the water and find the leak. Well I went riding yesterday and while waiting at the dock for a friend to get there, I decided to look around for my leak. Engine at idle speed I could see water dripping down off the alternator. Within a minute I found that the clear 1/2" hose that exits the transmission and feeds the hot water into the exhaust was touching the alternator housing. I pulled that hose and there was a pencil sized hole in the hose. I cut 2" off the hose and reinstalled it. Then I loosened the bracket holding the metal tube/cylinder that the 1/2" hose attaches to, loosened the hose clamps, then twisted that cylinder so that the 1/2" tranny return hose no longer rested on the alternator. The heat and friction from the alternator put a giant hole in that hose, it is on the driver side, remove the engine divider and the alternator is down low on that side. The only clear 1/2" hose down there is the tranny return hose.
Long story, but It was a 15 minute fix and now my boat is as dry as a bone (except for when friends dip my bow :cry:
Hope this helps someone.
 Post subject: Re: Found my water leak yesterday :D
PostPosted: Wed Nov 05, 2014 9:23 pm
Nice write up! The one thing I miss about a mid engine boat ..... harder to just pop the cover and inspect for leaks. Good catch and I'm sure someone else (probably me) will need this fix too.
Users browsing this forum: Google Adsense [Bot] and 48 guests
