It is currently Tue Nov 10, 2026 1:37 pm
[ 9 posts ] |
ridebutter
Post subject: Cruise Control Delay Posted: Mon Jun 16, 2014 12:31 pm |
Just picked up my A22 on Friday, and I'm seriously impressed. Coming from my '09 210, I thought there would be things I missed, but so far I'm really happy.
One issue though, when trying to adjust the cruise speed there is a delay. It doesn't matter if we are at cruise speed, or sitting idle, the delay is the same. It is really annoying, and apparently there is a fix for it, but I'm not sure what it is.
Thanks!
_________________ Ridebutter Wakeboard School Cove Wakesurfers
away
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 8:07 am |
Joined: Tue Aug 06, 2013 1:43 pm Posts: 62 Location: Harrodsburg, KY
what do you mean by delay? sitting idle? do you mean the time it takes for the number to change when you toggle the switch? When I toggle it is about a second per change or I can hold it down and it moves faster. Please elaborate and maybe some people can help you out.
_________________ 2013 Axis A22 Delta Universal Surf-Tab 750's rear lockers 950 Arrow under front seats stock tanks full
ridebutter
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 8:51 am |
Yeah it takes a second when I push the switch, I have been on an older axis and it changes instantly. The tach just has a delayed response to the switch.
"Sitting Idle" I was referring to setting the speed before I went under power or changing the speed while under power, it makes no difference.
vanamp
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 1:42 pm |
Same delay on my 2012 A22. Not sure why its delayed but im already used to counting my clicks.
Ferral
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 9:46 pm |
Joined: Mon Apr 09, 2012 10:50 pm Posts: 344 Location: Forest Lake, MN
ridebutter
Post subject: Re: Cruise Control Delay Posted: Fri Jun 20, 2014 9:52 pm |
Fishn4four
Post subject: Re: Cruise Control Delay Posted: Mon Jul 14, 2014 5:49 am |
Joined: Mon Dec 16, 2013 4:52 pm Posts: 170 Location: Tri-Cities, TN
I noticed that my 2014 T22 does the same thing. Sometimes it changes instantly and other times it takes forever for the changes to register. its when we switch from wake to surf or surf to wake that I notice it most.
_________________ 2014 Axis T22
DatTexasBoy
Post subject: Re: Cruise Control Delay Posted: Tue Jul 15, 2014 6:21 am |
Joined: Thu Dec 15, 2011 7:57 am Posts: 779 Location: East Texas
I have noticed with my 14' that you have to ease into the throttle especially at lower speed settings on cruise. I use to be able to gas it all the way and it would just pick it up on my 2010 but not on this one.
Try just using enough to get on plane and then give it a little more to set cruise.
_________________ 2010&2014 A22 2012&2015 MB 2016 Supra SA400
ecore66
Post subject: Re: Cruise Control Delay Posted: Sat Aug 02, 2014 6:03 am |
[ 9 posts ] |
Users browsing this forum: No registered users and 37 guests |
