It is currently Thu Nov 12, 2026 6:20 am
 Post subject: Trailer jack
PostPosted: Wed Jun 11, 2014 12:12 pm
Does anyone have problems with there trailer jack? Mine is a Fulton, I use it mostly in salt water and after we launch the boat whoever parks the truck puts the jack down so the water runs out then once we get home we rinse and wash every thing on the boat and trailer. My jack just keeps getting stuck and I have sprayed WD40 on the shaft and ran it up and down, then repeated that and just nothing seems to keep it from seizing up. Any one else have this problem?
Sink Responsibly
 Post subject: Re: Trailer jack
PostPosted: Wed Jun 11, 2014 12:26 pm
WD-40 is a cleaner, NOT a lubricant. You need to use Marine Grease on it.
PostPosted: Wed Jun 11, 2014 2:53 pm
you need to replace it .... I greased mine and its worse now ... I think another members broke .... plastic junk
PostPosted: Wed Jun 11, 2014 3:13 pm
It is a solvent with some lubricating properties. Definitely not a lubricant though.
PostPosted: Wed Jun 11, 2014 3:52 pm
Yup mine sure snapped on me when I was moving it back into the garage. Pretty pissed but what can you do.
PostPosted: Wed Jun 11, 2014 4:57 pm
WD-40 means water displacement 40th formula ....... I knew that without googling it but it's pretty easy to google it to confirm it
Wikipedia calls it a lubricant http://en.wikipedia.org/wiki/WD-40
Users browsing this forum: Google [Bot] and 59 guests
