It is currently Mon Aug 31, 2026 7:23 am
 Post subject: Where are the standard 900 lbs ballast in a 2009a22
PostPosted: Tue Oct 18, 2011 10:09 am
Hello to all, I want to buy a used Axis A22 2009 and I want to know if the standard 900 lbs of ballast are in the back seperated or one in back and one in the front? Thanks
 Post subject: Re: Where are the standard 900 lbs ballast in a 2009a22
PostPosted: Tue Oct 18, 2011 10:41 am
You have a center one and 2 seperate ones on each side under the rear locker floors.
PostPosted: Tue Oct 18, 2011 11:23 am
200lb hard tanks under each rear hatch and a 500lb tank under the center floorboard.
PostPosted: Tue Oct 18, 2011 2:04 pm
Great thanks it appreciated !!!!
