It is currently Thu Nov 12, 2026 7:17 am
 Post subject: impeller pump leaking
PostPosted: Sat Jun 07, 2014 7:00 pm
We just brought home a new to us a22 with LS3. Anyway, it has a fresh water flush. I hooked up the garden hose and it blew off a coolant hose off the raw water impeller pump. Anyway, I hooked everything back up and started the engine and noticed the impeller pump is leaking from what looks like to be the cover plate. I tightened the hoses to the pump already.
Is there a seal between the pump housing and the cover plate for the impeller? It drips water quite a bit.
 Post subject: Re: impeller pump leaking
PostPosted: Sun Jun 08, 2014 7:43 am
There is a thin foam gasket, probably have to buy an impeller kit to get it though, they're not much and since you just bought it used may be a good idea to change it anyway
PostPosted: Sun Jun 08, 2014 7:38 pm
Yea there's a foam gasket and like 4 small bolts
Take it off and If u haven't replaced the impeller in the last season then do it too
It's cheap insurance for that pricey motor
Users browsing this forum: Google Adsense [Bot], Majestic-12 [Bot] and 55 guests
