It is currently Thu Nov 12, 2026 7:55 am
 Post subject: Where/How to mount amp
PostPosted: Wed Mar 26, 2014 7:58 am
My boat is sound pack 1. No existing amplifiers. I need to mount one for my tower speakers. Doesn't look like there is any pre-existing board installed to mount an amp to. So I need to install one. Where does it go? Is it safe to screw into the hull somewhere? How big of a screw can I use?
Pictures are usually worth a thousand words.
 Post subject: Re: Where/How to mount amp
PostPosted: Wed Mar 26, 2014 8:42 am
viewtopic.php?f=14&t=2249&start=10
The screws for mine was about 1.5 inches long.
PostPosted: Wed Mar 26, 2014 11:45 am
I guess I should have searched.
<3
#nohomo
PostPosted: Wed Mar 26, 2014 12:40 pm
<3
#nohomo
The subject matter expert on doing this is Bryce. He can answer any detailed questions you may have. He installed all his stuff from SP1.
PostPosted: Wed Apr 02, 2014 5:08 pm
Bear in mind that the amp board is fastened to blocks that are adhered with plexus or weld-on adhesive to the hull. Do not attempt to screw into the sidewall or hull, as you will simply bust through the other side.
Peter
Smooth Water Sports, LLC
peter@smoothwatersports.com
Facebook
Users browsing this forum: Google Adsense [Bot] and 61 guests
