It is currently Mon Oct 26, 2026 8:19 am
 Post subject: What octane gas are you using?
PostPosted: Mon Aug 01, 2011 4:11 pm
What octane gas does Indmar recommend and is anybody is using anything else?
 Post subject: Re: What octane gas are you using?
PostPosted: Mon Aug 01, 2011 10:08 pm
Regular unleaded, 87 Octane, I have not seen anything else saying you had to run higher...I have the AR335, may have to run higher on the 400 depending on compression.
PostPosted: Tue Aug 02, 2011 3:32 pm
89 without ethanol
PostPosted: Tue Aug 02, 2011 5:30 pm
Where do u get gas without etanol these days and is it allot more expensive?
PostPosted: Fri Aug 05, 2011 9:26 am
we run regular unleaded @ about 87... same in all of the cars... no issues, cost too much to run the higher stuff!
2010 Axis A22
PostPosted: Fri Aug 05, 2011 10:15 am
91 in the 400.
PostPosted: Fri Aug 05, 2011 2:37 pm
There are a couple (out of ~20) Marinas that I know off on my lake that carry the 100% good stuff. Ethanol is a big issue here with the bass boats and antiques for different reasons, but there seems to be a high consciousnesses about the issues around here. I luck that it also happens to the closest fuel on the water and happily pay just under $4/gal for it. Maybe a little cheaper elsewhere on the lake. VA residents also get $.17/gal rebate. :-) Even some of the ethanol marinas have a 'special' marine blend that is basically including an additive like this: http://mystarbrite.com/startron/ One in particular marina here with this also has 24 hour pay at the pump and I have to make use of this occasionally - no discernible difference in performance. YMMV
PostPosted: Fri Aug 19, 2011 12:45 pm
You can't get it around houston area, closest is san antonio, or waco, try this web site buyrealgas.com
PostPosted: Fri Aug 19, 2011 2:08 pm
Keep Looking - There are 2 marina and one gas station I am aware of in my immediate vicinity that are not on that map...
PostPosted: Sat Aug 27, 2011 7:52 am
I got the standard motor, and I thought I read that 89 octane was the recommended octane for that motor? So I can run 87 octane with 10% ethanol?
