It is currently Fri Sep 25, 2026 1:11 pm
[ 3 posts ] |
gibbs114
Post subject: Front Ballast Bag Posted: Wed Jun 19, 2013 7:58 am |
Joined: Wed Nov 30, 2011 8:08 pm Posts: 770 Location: West Tennessee
I know this has been on here before but I can't remember the fix for it. The front bag is losing water when filled what do I need to fix this problem.
_________________ Gibbs Malibu 23 LSV
Dave.Mishchenko
Post subject: Re: Front Ballast Bag Posted: Wed Jun 19, 2013 8:16 am |
I recently rerouted my fill hose and added a check valve. I've tested it once and it seems to hold water much better than in the past.
I beleive Walter added a fill loop when he did his setup to prevent passive filling. I haven't checked to see if my setup is doing that.
_________________ 2009 - A22
Walter
Post subject: Re: Front Ballast Bag Posted: Wed Jun 19, 2013 10:55 am |
There are a bunch of ways to go about fixing this problem but the easiest is to just reach in there and close the valve after you fill it up, I went to the trouble to put in one of the vented loops by the glove box, and it worked perfect, but now I took out all the fittings and fill the bag on top of the seat with a tsunami pump. Takes a bunch more water on top but it helps the surf wave getting 300 more in there.
[ 3 posts ] |
Users browsing this forum: No registered users and 99 guests |
