It is currently Thu Sep 24, 2026 4:01 pm
[ 10 posts ] |
Axis Freak
Post subject: Lost thrd handle that threads into towerto hold it up . Posted: Wed May 29, 2013 6:53 am |
| Boater |
Any suggestion what to do on keeping these in place ?And also where to buy more. It was real rough this weekend. Also has anyone tried to drill and just pin the tower up . just need some help on determining how to prevent this from happening again. Thanks My Axis Buddy's
morrisdl
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Wed May 29, 2013 9:53 am |
Are you talking about the rubberized knobs?
Walter
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Wed May 29, 2013 9:56 am |
Axis Freak
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Wed May 29, 2013 11:48 am |
| Boater |
Yes the Rubber Knobs that thrd into the tower to hold it up into place. I have to take the tower up and down on every use due to the fact of storage. Thanks
Axis Freak
Post subject: Re: Lost thrd handle that threads into tower to hold it up. Posted: Wed May 29, 2013 12:38 pm |
| Boater |
what's the pro and cons of drilling all the way through and just having pins instead of screwing in and out each time to lower and raise. Thanks for the help my friends !!!
mikeakatex5
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Wed May 29, 2013 5:20 pm |
| Newbie |
Hey Walter do you know which of those knobs best match the ones axis uses?
Walter
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Thu May 30, 2013 7:42 pm |
No, not without having one to compare to.
morrisdl
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Fri May 31, 2013 7:37 am |
I have an extra knob, but the rubber is a little chewed up from a run in with the lift -- free if you are interested Ill post a pic.
morrisdl
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Fri May 31, 2013 7:39 am |
I dont think replacing the bolts with pins would give you the same tower stiffness, but I could be wrong. If you found replacement bolts with hex heads in black I think it would look good and you could use a cordless drill to more quickly remove them.
Axis Freak
Post subject: Re: Lost thrd handle that threads into towerto hold it up . Posted: Fri May 31, 2013 1:22 pm |
| Boater |
Thanks Cordless drill is the ticket. Doug
[ 10 posts ] |
Users browsing this forum: No registered users and 81 guests |
