It is currently Mon Oct 26, 2026 2:49 pm
 Post subject: 2013 Axis PnP
PostPosted: Thu Feb 21, 2013 4:35 pm
Have had my 2013 axis for a little over a week now and its been great. My friend has been bringing his fat sacs with him when we go ride, two 400s and a 540. These have been great for surfing but it just too much hassle, especially when switching to a goofy wave. So I'm curious about the PnP. Now it looks different to me. The rear lockers only have one hose with a cap on it. And the bow has no hoses whatsoever. I assume the rear hoses are both fill and drain? This being the case I would swap out the threads on the end of the hose for a quick connect. Now I have no idea what to do with the bow.
also I was planning on going with two 1100's in the rear and the normal bow sac.
File comment: here is a picture of our wave with the 540 in the locker the 400 on the seat a 400 on the floor and the stock center full. Oh yeah and i'm 6'2'' sooo
 Post subject: Re: 2013 Axis PnP
PostPosted: Fri Feb 22, 2013 7:33 am
If you search this site, you can find some very good threads about the PNP. Also you will be able find "how to" on installing the bags in the rear.
I know they changed it up a little for the 13 model but there is a ton of info out there to guide you.
PostPosted: Sat Feb 23, 2013 12:03 pm
I did look through here at some of the PnP posts but nothing about the 2013.
PostPosted: Sat Feb 23, 2013 3:06 pm
I'm not sure how much, but I do know that they changed the PNP for 2013. As far as mine it looked a lot harder then it really was. The front one was real easy. It really is just plug an play. I'm sure you can follow the 2012 installs. On the rears I have read that you have the option to fill tank first.
PostPosted: Sat Feb 23, 2013 7:49 pm
Try this thread out.
viewtopic.php?t=1645
PostPosted: Sun Feb 24, 2013 6:07 pm
I'm trying to get the video made within the next week on how to set up your 2023 plug n play.
Gibby
2011 A22 Vandall
