It is currently Mon Oct 26, 2026 3:28 pm
 Post subject: Sumo 900lb sac
PostPosted: Mon Feb 04, 2013 4:40 pm
I just ordered 2 sumo 900lb v surf sacs to replace my fly high 400's. I was just wondering if I am going to need different fittings than the 3/4" flo rite quick connects that are currently on my fly highs?
 Post subject: Re: Sumo 900lb sac
PostPosted: Mon Feb 04, 2013 5:48 pm
What are you going to do with the 400's? I may be interested if you are selling. What model number are they as Fly High has about 3 models that are 400 lbs. W713, W701, or W030?
Thanks
Bama Axis
PostPosted: Tue Feb 05, 2013 2:13 am
ko... if the fitting on the 9s are the same as the 6's and bow sack I tested, then you will need to get the 1" thread in quick connects that fit your connections. Straightline has them, just order them, thread them in, and your bags will plug right in.
http://www.wakemakers.com/wakeboard-bal ... t-fittings
towards the bottom of page is the "straightline 1" thread to 3/4" quick connect" or something along those lines. 5 bucks each.
PostPosted: Wed Feb 06, 2013 4:08 am
5 bucks each but min $25 shipping to canada :(
PostPosted: Wed Feb 06, 2013 12:38 pm
lame... call straight-line directly and get them to send you those connections for free or threaten them with going with Fly-High!!! :D
PostPosted: Wed Feb 13, 2013 12:34 am
If the shipping is too expensive to have quick connect fittings shipped internationally simply use 1" thread x 3/4" hose barb elbow fittings from Home Depot. That is the reason why Liquid Force went with NPT fittings instead of a proprietary thread like Fly High. They are only $1.50 each and will do the trick.
PostPosted: Fri Feb 15, 2013 8:54 pm
Thats a great idea spencerwm, I hadn't had a chance to look into that yet. Now that I know, that is definitely what I am going to do. Hooking it up with home depot connectors will leave me with a bunch of quick connects to play with on my 400's around the boat :D
Now all I need is for the lake to thaw out :(
PostPosted: Sun Feb 17, 2013 11:44 am
Woot... thanks for the tip man. $1.49 ea :)
PostPosted: Sun Feb 17, 2013 10:15 pm
Sumo Bow Sac for A20 and A22 update:
Was told by a reliable source that they will be hitting the stores in April...
PostPosted: Mon Feb 18, 2013 5:13 pm
Fingers crossed it will actually be a little sooner. The sac looks good and fits really well. It will be less expensive than Fly High and will be larger if that has not been established on another thread already.
