It is currently Fri Oct 23, 2026 3:20 pm
 Post subject: Stock Sony Head Unit Question
PostPosted: Mon Nov 12, 2012 12:38 pm
I have the stock Sony Head Unit in my 2012 A20... it has the USB input hook up under the throttle... yes this is perfect for the iPhone and iPod hook up which I use... but are you all using anything else for you music source... I basically bought a iPhone this summer over my droid because it is easier to link up my Pandora thru iPhone to USB... my question is are you all using any other phone device that can easily play Pandora, Music Files... etc. I thought it was odd that the stock headunit while it is awesome no doubt... doesn't provide an Aux input...?
2015 T22
 Post subject: Re: Stock Sony Head Unit Question
PostPosted: Mon Nov 12, 2012 1:54 pm
The back of my unit has a red and white hook-up for RCA's. Went to wal-mart and bought a cable that connects to the red and white RCA's and converts to an aux input to plug into any other device. I do not have a direct aux input but maybe you will have something similar to this. It's not under the throttle as the USB it just hangs directly under the deck. Good luck!
PostPosted: Mon Nov 12, 2012 3:48 pm
I found a couple blackberry Bluetooth music gateways on clearance. There are a couple other similar product but can't believe these havt taken off in popularity. Works awesome!
Users browsing this forum: Google Adsense [Bot] and 17 guests
